4l80e swap 2003 1500 ecsb
i am swapping in a 4l80e in my 2003 silverado 1500 ecsb and i need info on what swap yoke to use to make my stock two piece steel driveshaft work with the 4l80e
Its what ever the factory u-joints are. somebody on another forum said that I would have to shorten my drive shaft but not sure it that true or not. I cant just install the engine and transmission and measure its my DD so im trying to get my ducks in a row first so im not down long.
This here is what you want GM Turbo 400, TH 400 / 4L80E Transmission & T/C Slip Yoke 1350 (331) U-JOINT | eBay
I had to trim 1.25 inches off of the yoke and non on the ds. You'll also need a conversion ujoint if you are going to run the stock ds, I used a moog 447
You dont need to shorten DS on the 80e swap but may or may not have to cut the yoke down, it depends because there are various output shafts (all 32 spline) on the 80e as well as various yokes.
When I did the swap on the 99 excab I used the Trans and yoke out of a 99 express 2500 with a puj 447 conversion u joint from napa. Factory 1500 u joint is a 3r and the 4l80e is a 1350.
