Power Window Help
Power Window Help
I have a 2000 silverado and the driver side window has taken a dump. I jumped the motor and it still functions normally. I replaced the switch and it is still doing the same thing. It is not sending any power to the motor. I dont have a wiring diagram so that would help. All other functions on that door work, even the passenger switch on the drivers side. Any help here?
PT's Slowest Truck
On most vehicles, the wires in the door harness are prone to breaking due to the door opening and closing and constantly moving those wires. (in the rubber harness protector going from the body to the door in the door jamb). Might want to check if you have power going in to the harness in the left front kick panel. If there's power and ground going in and none going to the motor, you have a broken wire there. (do this while activating the switch obviously)
Superman09
09-25-2015 05:55 AM
b4z
09-10-2015 06:58 PM
