2011 GMC Yukon Denali questions?
So I've been looking at the 2011 AWD Yukon Denali's and what I know is they come with the 6.2L motor, 6L80e.....
What rearend is spec'd for these beasts? Is the frame painted or wax coated? What AWD xfer case is used? thanks! |
Originally Posted by moregrip
(Post 4610666)
What rearend is spec'd for these beasts? Is the frame painted or wax coated? What AWD xfer case is used? thanks! http://archives.media.gm.com/us/powe...0BFL%20LoR.jpg |
Transfer Case Description and Operation
The Borg Warner (BW) model 4485, RPO NR3 transfer case is a 1-speed, full time, all wheel drive (AWD), transfer case. The transfer case provides power to both axles, through an external planetary type differential, which has 2 different sets of pinion gears. The planetary differential provides a 40/60 torque split, front/rear, full time. This means both axles are constantly being driven for maximum traction in all conditions. |
My wife has a 2010, the frame is still wax dipped. I think it also has 3.73 gears but I may have to look to make sure.
Originally Posted by scooter k
(Post 4611097)
i find it a little funny that a waxed vs painted frame is a selling point..
Originally Posted by BlackGMC
(Post 4611430)
Grippy,
unless you require AWD or Denali you can get a Max trailer package with the same drivetrain and rear end in 4wd or 2wd for way less money even in the LTZ or STL Trim package. Just sayin |
Originally Posted by Allgonoshow
(Post 4612090)
Grippy,
(Post 4612202)
I didn't know that....hmm....I thought the standard engine was the 5.3 in the Yukon/Tahoe setups?
I believe you can get the 6.2 in the Sierra/Silverado's with the lower packages, but not in the Yukons/Tahoes. |
