1999 GMC Gauge Problems..........
I have a 1999 GMC RCSB with a 5.3L and average km.
The problem I'm having is with the gauge cluster.................. The ABS and E-Brake lights come on and go off at random The fuel gauge goes from full to empty with the LOW FUEL light ON when the tank is FULL. I can hear the FLASHER relay clicking ON and OFF when driving. I HAVE TRIED A 2nd CLUSTER WITH THE SAME RESULTS. Anybody have any ideas??????:sigh::sigh: |
replace fuel pump assembly to fix gauge
have someone w tech 2 scan abs module but its probaably a fragged abs unit or wheel speed sensor 99's had terrible problems with crappy abs units. cant help you on flasher any weird turn signal lights illuminating to notify you a flasher is closing. |
Originally Posted by 01WS6/tamu
(Post 4906432)
have someone w tech 2 scan abs module but its probaably a fragged abs unit or wheel speed sensor 99's had terrible problems with crappy abs units. cant help you on flasher any weird turn signal lights illuminating to notify you a flasher is closing. Can I use a newer ABS module? |
