Walbro 400, Aeromotive Regulator, Racetronix Harness
Old Mar 21, 2015 | 03:23 PM
Ferocity02's Avatar
Default Walbro 400, Aeromotive Regulator, Racetronix Harness
Walbro 400 LPH fuel pump, mounted inside a 99-02 bucket. Bottom of the bucket is still intact so no need to worry about running the tank low. Never had an issue with the bucket running dry either during hard acceleration. Uses a plastic hose with oetiker clamps like stock, no need to worry about a cheap rubber hose falling apart. Upgraded wiring from the pump to the connector, and has the upgraded flat 4-pin connector. SOLD
Aeromotive fuel pressure regulator kit. Uses an A1000 regulator in black, -6AN fittings, and stainless braided line. The fittings allow you to connect it to the factory feed line and rail. Comes with a custom bypass plug that replaces the factory regulator in the rail (99-02), the plug uses the factory regulator o-ring and clamp. Also comes with a custom bracket to mount the regulator to the brake booster. This was installed on my 2001 5.3L, mounting might be a little different on other vehicles. Will not part out. SOLD
Racetronix fuel pump harness, part# FPWK-017W. Uses the factory 4-pin square plug to connect to the truck's harness, then a flat 4-pin connector to connect to the pump. Power wire was cut to length for my 01 Silveraso ECSB. I used "Stud #1" in the fuse box for the pump power, comes with a large 20A fuse to use this stud. SOLD
All three were used for about 1000 miles. PM me with any questions.
Old Mar 22, 2015 | 10:47 AM
treylittlefield's Avatar
Pm sent
Old Mar 22, 2015 | 08:53 PM
twistedchevy's Avatar
Sent pm
Old Mar 24, 2015 | 12:44 PM
jetfixrguy's Avatar
If for some strange reason the buyers back out, ill buy it all.
Old Mar 24, 2015 | 03:09 PM
Ferocity02's Avatar
Everything shipped out yesterday, but a few people are asking about the plug I made. I'll be making a few more if anyone is interested, PM me.
Texas5.3_1251
Mar 5, 2016 08:10 PM
TAPyvehc93
Jan 8, 2016 10:47 AM
12secSS
Sep 16, 2015 03:59 PM
chevstang421
Sep 10, 2015 09:16 AM
slowswb
Sep 5, 2015 02:27 PM
