224/222 cam, Low compression 369 ci short block
Copy from LS1tech, I sold my last cam to a truck guy, so here goes....
Cam info/specs:
New this year from Hi-Tech motosport. (Custom grind by Comp Cams)
I:224 E:222 .581"/.566" 113 LSA
Approx 1k miles on it, and I have the Cam card. $250 shipped UPS Ground
Nice idle, not monster, but nice rumble with good vacuum/street manners.
I went times in sig with this cam, with low compression Iron block. Cam is out and ready to ship, just need to box it up. I ship UPS daily at work.
Pic here :http://j.cz28.com/224-222%20LS1%20Cam.jpg
Short block:
369ci Iron Block 4.030" x 3.62" my setup was 8.9:1 comp ratio
Forged JE Pistons (have spec sheet from JE) - 28cc dish with valve reliefs. Factory crank and rods. Balanced (have spec sheet with weights)
under 6k miles, never seen boost. I bought the car with this motor in it. The guy that had it before me had this motor built for a turbo kit he had, but ran out of money, and had to sell the turbo to pay for this motor. I bought the car n/a with less than 500 miles on motor. I planned to boost it, but it ran so well as is. I just took it out this weekend, and it is in a crate ready to ship. Motor always had good Oil pressure, and pan was clean when I took it off this weekend. I am selling b/c I just picked up an aluminum short block. Again, the combo ran real strong (A4)- 11.80 @ 114 (116 best mph) w/ 3650# weight. I ship daily w/ con-way (ccx) and we get a large discount.
$1200/bo EDIT ---> I am willing to go $1200 shipped to Cont. U.S. Business address, or you can pick it up at the terminal closest to you. Truck lines have large fees for Res. deliveries. It will be shipped wrapped in plastic in the same box SLP uses for it's shortblocks via Con-Way (CCX).
Pics here:
http://j.cz28.com/369%20ls1.jpg
http://j.cz28.com/369%20ls1%202.jpg
http://j.cz28.com/369%20ls1%203.jpg
http://j.cz28.com/369%20ls1%204.jpg
Any other questions, just ask. I can also supply references if you want. I can accept PayPal also, just add their 3%
'J (jman812 ebay ID)
__________________
11.80 @ 114 w/ 1.6x 60' 369 ci Iron Block
8.9:1 C.R. N/A 3650#
3.23 Yank SS3800 FLP level 4
Bracket Racer
http://j.cz28.com jman812@hotmail.com
Cam info/specs:
Short block:
Pics here:
__________________
Bracket Racer
how will a silverado 5.3 heads work with this motor???
Will is bolt directly into a 5.3 wilverado (2003)
PM me with details!!!!!
How much extra would it be to get Forged Rods and head studs and bolts put in!!!!
Shortblock sold.
Cam info/specs:
'J
Cam info/specs:
'J
113, 222, 369, 383sbc, 53, acceptable, block, cam, compression, level, low, performance, sbc, short, vacum
