Y-pies, Collectors, and Mufflers
Old Mar 24, 2009 | 06:11 PM
Cooder5.3's Avatar
Default Y-pies, Collectors, and Mufflers
I have ordered a set of Pacesetter Ceramic Coated long tubes for my 5.3 and I was wondering what you guys did to connect the y-pipe to the collector on the header? I have seen a link for the clamps, but I was just wondering what is teh best painless way to connect them together and not worry about an exhaust leak.
Also I was on youtube and seen a clip of a Chevy RCSB with Pacestter long tubes and true dual Bassani mufflers. What is everyodies opinion about them? How do they flow or and what not? I'll post a link to the clip:
http://www.youtube.com/watch?v=QKshh...eature=related
Old Mar 24, 2009 | 06:14 PM
GMCtrk's Avatar
Torctite stepped 3" band clamps and wrap the joint with aluminum foil first. That's as good as you can get with a clamp. Of course, if the pipes dont fit together well it's going to leak. I'd go ahead and get the Flowmaster ball and socket's welded in.
Old Mar 24, 2009 | 06:16 PM
sonoma43's Avatar
band clamps will work just fine.
Old Mar 24, 2009 | 07:14 PM
BigCountryx's Avatar
no leaks from my band clamps. I like the Walker Mega clamps, but the Acceseal clamps allow a little more flexability like on the passenger side collector on the pacesetters and the LPPs like I have. The placement of the O2 bung doesn't allow the use of a stepped band clamp. You run into this on inlets/outlets of the mufflers as well. The accuseal clamps are not stepped, but when you torque them down, they will "mold" to the slip and seal rather well. I used high temp, sensor safe, copper based rtv. it makes removal slick as well.
Old Mar 24, 2009 | 07:17 PM
terravast4's Avatar
I am using dynatech V-clamps.
Old Mar 24, 2009 | 07:39 PM
Cooder5.3's Avatar
I seen the Dynatech V-clamps. I thought about using those at the headers and then some band clamps on all other connections in the y-pipe. But since i have to go to the muffler shop anyways I should probably have the yipe welded all together to ensure no leaks.
Old Mar 24, 2009 | 07:53 PM
lukesdad04's Avatar
+1 on the Walker Mega clamps, mine don't leak either. If you have your ypipe welded you will probably never get it back off without cutting it. I just cut a notch in my band clamps to clear the 02 sensor.
Old Mar 24, 2009 | 08:10 PM
BlackGMC's Avatar
Resident Retard
V-Bands!!!!!!!!! That is what i run, no leaks, no gaskets!!!
Old Mar 24, 2009 | 09:09 PM
budhayes3's Avatar
PT's Slowest Truck
This stuff works well, I used it on the slip joints for my StainlessWorks headers and y-pipe with the supplied band clamps. Good to hear that it aids in removal too, as I have to remove the y-pipe eventually when I swap my trans, and again when I do my LQ9 swap
Old Mar 24, 2009 | 09:27 PM
QLF's Avatar
QLF
I used Walker band clamps for my collectors, Y-pipe, and to attach my intermediate pipe; I can't complain, after changing out one due to a poor slip fit on my ORY that caused a leak, I haven't had a problem.
Just be sure retorque them after a few heat cycles and you'll be Golden. There is a higher possibility of leaks if your slip fit isn't tight, but it's definitely the cheapest option.
