-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Wierd vibration from brake pedal with cam.. (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/wierd-vibration-brake-pedal-cam-413492/)
03GMC Mar 9, 2008 11:42 AM
Just had my 215/220 cam installed last night. Everything seems great and it lopes pretty hard with the 112 lsa. Only thing is the vibration from my brake pedal while at a stop. Feels like the brake booster or something? Its not tuned yet for the cam and I'll be getting a stall put in shortly.
06sierra5.3 Mar 9, 2008 12:18 PM
put the converter in it, then tune, should be alright.
sbw9056 Mar 9, 2008 12:25 PM
Decreased vacuum to the brake booster.
03GMC Mar 9, 2008 12:40 PM
So tuning can increase the vacuum to the brake booster?
BlownChevy Mar 9, 2008 01:45 PM
negative. How much vacuum do you have a idle?
03GMC Mar 9, 2008 01:47 PM
No idea. How do I figure that out? Has something to do with the cam. It was fine, I put a cam in it and now it does this. :bang:
sbw9056 Mar 9, 2008 02:40 PM
Have it tuned. Increase your idle speed. Get a higher stall converter.
BlownChevy Mar 9, 2008 05:28 PM
all three are things that are NOT going to change his problem.
1SlowHoe Mar 9, 2008 05:33 PM
Whats the overlap on that cam? A 112lsa doesnt usualy cause this issue.
Nick™ Mar 9, 2008 05:43 PM
somewhat true. The 2003 trucks have a vacuum pump on the brake booster that should compensate. Under other circumstances the vacuum can reduce the power of the brake booster.
can we get more description of the "vibration", is it while stopping, sitting at idle, does it change with the lope/ surge of the motor?
