Where is OIL PRESSURE SENDER located?
Old Aug 23, 2003 | 05:52 PM
eallanboggs's Avatar
Default Where is OIL PRESSURE SENDER located?
I can't locate the Oil Sender. I think it might be behind the starter motor, but I'm not sure because the factory Helm manual doesn't even mention the oil sender. The Haynes manual has a WORTHLESS photo that shows the passenger side bank, oil dip stick and a handheld oil presurre gauge that the photo implies is connected to the oil sending unit which can't be seen in the photo. I want to install a mechanical oil pressure gauge to monitor the pressure on startup as I have just installed a new cam, ported oil pump and Rollmaster Double Row Chain. It would be nice to see the oil pressure on a mechanical gauge when I first start the motor after changing these items.
Old Aug 23, 2003 | 07:41 PM
hohl's Avatar
Default Re: Where is OIL PRESSURE SENDER located?
Look at this thread. https://ls1tech.com/threads/showflat...rue#Post675122
Slowverado broke his and has a picture of where it is -- at the top back of the block behind the intake.
Old Aug 23, 2003 | 07:43 PM
Banned
is your factory oil pressure gauge not working? i know that auto meter gauges give a more "accurate" reading but the stocker can't be that far off to where you wouldn't have a good general idea of what's going on.
pupi305
Sep 14, 2015 11:40 AM
truefire04
Sep 11, 2015 10:51 AM
Noah Burns
Sep 7, 2015 05:50 PM
superchomper2003
Aug 26, 2015 09:39 AM
