Whats diff. with a cam only swap.
I'm thinkin about swaping to a more low end cam. Its been a couple years since I did my first swap so I'm a lil rusty on the procedure. Whats different with the swap if I don't need to change the springs and rods? Hopefully its a lil less complicated.
I know I should change the springs too but I'm poor. And if anyone has a comp 212/218(? I think thats the popular one) sittin around or wants to trade let me know. |
what springs are you running now, 918's? how many miles are on them? the swap will be a breeze w/o changing the springs. cam is the easy part, only takes a couple hrs.
I have 918s with prolly 30k on them? I've babied them though, Never actually raced anyone before or takin it to the track. I used the ls1howto website to do my first swap. How is it different? Do I stil have to pull the intake and valve covers? or just yank it out, and wiggle the new one in?
with some dowel rods you don't have to touch the intake other than removing the air box.
just pull everything infront of the engine. once you get the timing chain off slide the dowel rods into the 2 holes so that they'll slide into the groves of the lifters. spin the came to get em all. You also need to shave part of the dowel rods but someone else can post that cuz i'm not sure how much to shave. Once it has all the lifters just slide the cam out and slide the new one in. |
spin the old one, put new one in...
rockers must be removed, than pull the pushrods out. don't need to touch the springs. use dowels to hold lifters. follow ls1howto up to the spring swap.
Dowel idea failed for me, I wouldn't take the chance of sticking a stick in such a vital oil gallery. buy the pen magnets for a $1ea at a dollar store.
ok see if I have this straight... remove front accessories and cover, remove valve covers, pull rockers and pushrods, and then I swap the cam? That should save some time not messing with the intake and especially springs
Originally Posted by Soquel
(Post 3955104)
Cam trade?
Hey,
I have a comp cam grind similar to the one you want... 212/216 .520/.524 115LSA I also still have the card for it. Whats your full cam specs? i think i want to trade. Pm me if intrested. Thanks Brandon |
| All times are GMT -5. The time now is 08:19 AM. |
