What nos system would you guys recommend for a small shot?
Also is there any thing that I should do to my engine to make it nos ready or something that will make the engine last longer on nos.
Re: What nos system would you guys recommend for a small shot?
do you have a hypertech programmer, or diablo or anything? as far as a NOS kit i would go with the 5177 dry kit, if if you want to go with a different brand the NX GM EFI wet kit is awesome, and very very safe.
Sneaky pete!!!
not yet i want to get a westers pcm. the brand does not matter. i am not looking to use a huge shot of nos. how will my engine hold up over time with the use of nos?
NOS is a brand, i thought that's what you meant. NITROUS is what you are reffering to i guess. if you order a westers PCM have them pull some timing for the juice and you'll be fine.
but this is my daly driver and i want it to hold up.
i have heard that nitrous is bad for your engine and over time it will start braking things. i had a guy tell me that 17 hard drags using nitrous will blow the engine
nah, j4...guys like me and red2k have run huge nitrous shots for a long time with no troubles...you'll burn up your tranny before the motor if you just run it safe.
so there is no need to replace any thing in the engine. also i am thinking about puting a radix on my truck. should i go with a wet kit or dry kit.
well, a radix with spray is kinda pushin it...but i would go dry and get some BIG injectors. cut the catalytic converters off it and get some headers if you want the best for nitrous
