What Gauges to Install with the STS???
I did fuel pressure, boost/vaccuum and EGT. I installed the EGT on the exhaust manifold about 1 inch from the head. This is what the tech guy at Autometer told me. Gauge works great but I have heard about 100 different suggestions on what my temps should be!!!! So now I just have another cool gauge. Anyone have any ideas how to tune with EGT or at least use it to keep tabs on the engine?
Originally Posted by F8L Z71
Unredeemed, EGT gauge is a goo done to get but the problem with it is that with a rear mount kit I am not sure if anyone would know how to read the #s correctly since the temps most likely won't be the same due to backpressure from the turbo. The probe is usually the last in line. Now it will be between the turbo and manifolds.
Normally you put the EGT probe in the collector before the turbo.
Ahh ok... Then we still have the issue of what is a proper reading for their particular setup.. That's why for the price I'll stick with a wideband. LOL
Easy.. anything over 1600 will melt an aluminum block. So with that said, shoot for a target temp of 1500-1550 at WOT.
Then again it will take someone with a WB verify the gross generalization I just made.
You only need
#1 Boost
#2 Fuel Pressure
#3 Get a WIDEBAND o2 kit with gauge.
If you buy a cheapo air/fuel meter we will jump you and gang rape you!
#1 Boost
#2 Fuel Pressure
I have a pyrometer.... I'd like to throw it as far and as hard as I can...
Here's what is good for: a) beeping constantly when I have my right foot resting lightly on the floor (with the go pedal underneath of course) b) showing that my EGTs are between 1300-1600+ at full boost.
That's it. My EGT has never varied one little bit across 5-12psi, with or without methanol injection.
Originally Posted by 04BlackSilverado
Are there any guages that look similar to the guages in the truck for a stock look?
What does a WB measure? Air vs. Fuel, for lean or rich right?
And how much does a kit cost?
a digital voltmeter on the O2 sensor itself is a good way to instantly read rich or lean.
aftermarket blinky light A/F guages are garbage, and EGT guages should only be used as a guide, due to the fact that combustion chamber temps can often reach dangerous levels, much quicker than an EGT guage can react.
