what to do??
Old Jul 27, 2012 | 02:40 PM
TURBHOE's Avatar
I agree, but who woul want to go down in power? It's got to at least run the same times as I do now. . Just do it and get better than the damn 13 I get now. Not to mention bein able to tow same weight but soooo much easier.
Old Jul 27, 2012 | 02:59 PM
pewterliftedz's Avatar
a dirtymax with an allison for sure. You don't need twins to out run your current setup. A single turbo will do just fine. But hell if you want to be different twins would be sik..
Old Jul 27, 2012 | 07:00 PM
SLCviaAK's Avatar
You have the multi link rear suspension correct? Have you thought about getting a rear axle from an H2 and re drilling to 6 lug? Should bolt right in then . . .
Old Jul 28, 2012 | 07:43 AM
TURBHOE's Avatar
That's just a 9.5 14 bolt. I can get a straight bolt in from a new model caddy. I was concidering using the 10.5 or 11.5 and goin 8 lug all the way around. 97 dodge 2500 gasser front unit bearing bolt right up to stock 6 lug spindles for the fronts.
I was going to use the stock turbo for the little guy and just add on a big one to that. Quick spool and big power.
Old Jul 28, 2012 | 08:11 AM
silver-mod-o's Avatar
Hunt&Fisherator
The Allison would require a body lift... But there are some well built 80E's behind some DMax setups these days
Old Jul 28, 2012 | 08:59 AM
TURBHOE's Avatar
It's actually not so much the Trans as it is the a/c compressor and the intercoooler/radiator.
It can be done with out a body lift but it's not ideal. But the cool part is you don't need a full body lift. 2" on the front support none on the back bumper and then stagger the lift back. This way it just gives the leveled look most people want. For the front there is no need to relocate the bumper. Just use the hd bumper pad and grill. That will make up for the front gap. It's not quite as hard as it sounds. It's not simplistic by any means but not extremely hard to do. Cost is my biggest factor.
Old Jul 28, 2012 | 09:03 AM
TURBHOE's Avatar
Now getting a 9.25 front dif in there would be a big challenge. I would love to be able to figure that out. I'm going to look into it but it doesn't look promising.
Then there is the issue of no torque thrust 8 lug rims on the market. If you Know of any please let me know.
Old Jul 30, 2012 | 01:13 AM
TheGreat4.8's Avatar
Wait was 2 stroke Detroit diesel one of the options?
Old Jul 30, 2012 | 04:12 AM
03sierraslt's Avatar
Put a Cummins in it, just stretch the front a bit.
Old Jul 30, 2012 | 06:18 AM
TURBHOE's Avatar
i actualy looked into the cummins with an allison. but the dmax seems to have a mileage advantage over the 6.7 cummins. plus the dmax is all plug and play as far as wireing goes compared to the cummins.
