What compression ratio?
Old Oct 23, 2005 | 09:24 PM
Dark Halo's Avatar
Default What compression ratio?
I have a LQ9 6.0 and I was wondering what the compression ratio would be with a 64cc head? How do you figure up compression?
Old Oct 23, 2005 | 10:23 PM
Rhino79's Avatar
9 Second Club
I don't know how to figure the ratio but it will probably be in between 10:1 and 10.5:1.
Old Oct 24, 2005 | 12:04 AM
KLUG'S SS's Avatar
FormerVendor
Well I believe the LQ9 has 72cc heads and 10:1 compression ratio so with 64cc heads I think you would be around 11:1 or maybe even a little higher.
Old Oct 24, 2005 | 10:56 PM
Dark Halo's Avatar
I have been to 11:1 but then I was also told that a 59cc head would put at 11:1
Old Oct 25, 2005 | 11:35 AM
KLUG'S SS's Avatar
FormerVendor
Patriot Performance told me that a 66cc head on a LQ9 would put it at 11:1, there is some formula or something out there to figure it out I believe but I haven't found it yet.
Old Oct 25, 2005 | 01:40 PM
treyZ28's Avatar
the formula should be fairly inutitive to get close.
(head CC + 3.141*bore/2*headgasket thickness) /displacement per cylinder for a flat top piston will get you close. If you want to get closer, google it.
Old Oct 25, 2005 | 10:55 PM
Dark Halo's Avatar
thanks
zblee
Nov 11, 2015 12:41 AM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
Boyes50
Sep 8, 2015 12:06 PM
