What is code P0315.....?
Not sure what this code means
P0315 Crankshaft Position (CKP) System Variation Not Learned. I tried removing it with autotap and it will not remove the code. Any ideas? :confused: Here is a good site for defining codes Http://www.automotiveforums.com/t95876.html |
did you just install the tune or another pcm. if so you will need to do a relearn procedure for it.
http://www.nelsonperformance.com/faqs/passkey.htm |
Dont go to the above site there is a trojan virusautomotiveforums
man thanks i was just about to go there. :hail:
http://www.nelsonperformance.com/faqs/passkey.htm EDIT: Nelson pcm has been installed for just about 2 months, and now im getting this code. |
EFIlive has a crankshaft position relearn program,you basicly clear all engine codes and follow the instructions on the screen.That takes care of the problem.Or you can go to someone with a Tech tool to do the samething.
Most likely the dealership will have to do this with their TECH II.
| All times are GMT -5. The time now is 09:11 AM. |
