-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   What cat to use? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/what-cat-use-366104/)
NORCAL TBSS May 22, 2006 01:54 PM
What cat to use?
3 inch high flow cat im gona do a custom y pipe on my tbss. So what 3 inch cat should i use? Magnaflow?? catco??
help me out guys
krambo May 22, 2006 02:20 PM
Random Technology. :judge:
Do a search, there is some good info to be looked at. :cheers:
silver-mod-o May 22, 2006 03:11 PM
I'd say magnaflow personally but I am sure the others will flow well too.
1Bad454 May 22, 2006 03:34 PM
Random Technology
moregrip May 22, 2006 03:38 PM
Magnaflow HF Met Cats flow more and are less money, can't go wrong there.
BenKey May 22, 2006 04:40 PM
What type of core does the magnaflow have? Just curious.
NORCAL TBSS May 22, 2006 05:54 PM
SO IF I go on e bay and just get a 3 inch hi flow cat does it have to be 3 or 2 way etc. i dont think there are tubes hooked up to them. ALso smaller cat will let it flow more correct?
Out1aw May 22, 2006 06:09 PM
Naturally a smaller cat will create a less amount of time for the air to be restricted in, therefor flowing better.
ramdaspadhye May 22, 2006 10:30 PM
I've got a magnaflow 3" on my turbo tacoma and it does well...
Last Call May 23, 2006 09:35 AM
If your going with a magnacharger, go with a metallic cat. I dont think a ceramic cat will lost a long time with the high temps from the magnacharger.
I have magnaflow cermamic cats that flow 590 cfm, a ton of air. I would look into that.
