-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Walbro 400lph good enough for turbo? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/walbro-400lph-good-enough-turbo-523948/)
Cammed4ever Nov 20, 2013 08:50 AM
I am getting everything ready for when the turbo arrives and I am in the fuel matter right now..
I have been reading about dual 255's.. But a 400lph isnt enough? Or why is not more people using it?? Or what fuel pump should I buy?
I think i'll go with 80lbs injectors..
Aiming for over 600rwhp..
Thanks!!
kbracing96 Nov 20, 2013 09:05 AM
I just put a walbrow 450 in my truck before I sold it worked great!
kelsey_canard Nov 20, 2013 09:08 AM
I am running a walbro 400 on 10psi right now. Granted I am under turboed and don't spin that many rpms.
Cammed4ever Nov 20, 2013 09:27 AM
Do I need a FPR to set it up or do I just replace my existing walbro 255 for the 400??
Thanks!!
Ferocity02 Nov 20, 2013 10:11 AM
A 400 should be enough. I'm running a 255 right now on the stock wiring and it's been fine up to ~13psi, granted I have a return system and am injecting methanol. However I do think it's just about maxed out. Next step will be to upgrade the wiring and install a 400.
Cammed4ever Nov 20, 2013 11:47 AM
Is there a lot of wiring to upgrade?
timmay208 Nov 20, 2013 11:49 AM
id run a relay to the pumps, helps them keep 12v consistent . Im going to be running 2 255, one on stock wiring with relay added and other on a hob switch where it only turns on above 3-4lbs of boost
Noah Burns Nov 20, 2013 12:03 PM
do you do the relay in conjunction with a hot wire?
anyone have a "diagram" of such a setup?
timmay208 Nov 20, 2013 12:06 PM
just standard relay
12v wire from battery to relay
ground wire for relay
wire from relay to fuel pump
wire from factory harness to relay
Ferocity02 Nov 20, 2013 12:15 PM
Originally Posted by timmay208 (Post 5164505)
just standard relay
And a fuse somewhere in there :D
