-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Valvetrain question for my new camshaft??? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/valvetrain-question-my-new-camshaft-436651/)
QQuiksilverado Mar 9, 2009 12:40 PM
Alright guys I am getting ready to throw in my camshaft. it is a Comp Cams 212/218 112LSA the specs are ADV Dur intake-264 Exhaust-269 Duration at .050 is the 212/218 and the valve lift is .488 for the intake and .495 for the exhaust. My question is would it be ok to run the stock springs, rods, and lifters with this camshaft. I am asking since the valve lift isn't that high. I am not sure what the stock valve lift is but I am sure someone can throw me some intel on this. I just want to get my cam in and headers on so I can get it tuned.
white lightning SS Mar 9, 2009 01:01 PM
In your case I would definetly recommend upgrading to the yellow ZO6 springs. You can get a set for 70 bucks. Thats cheap insurance compared to dropping a valve. Push rods are also a weak link in the motor. Trick flow sells 5/16 x 7.400 pushrods for 75.00. Lifters, rockers, keepers, and retainers should all be O.K.
sonoma43 Mar 9, 2009 02:19 PM
Originally Posted by white lightning ss (Post 4150721)
in your case i would definetly recommend upgrading to the yellow zo6 springs. You can get a set for 70 bucks. Thats cheap insurance compared to dropping a valve. Push rods are also a weak link in the motor. Trick flow sells 5/16 x 7.400 pushrods for 75.00. Lifters, rockers, keepers, and retainers should all be o.k.
x2!!!
sickREDsierra Mar 9, 2009 04:48 PM
huh? i think the smallest 212/218 cam is around 522/529 lift... iirc
either way, the yellow z06 springs will hold you fine. can be had for 50-70 bucks.
sonoma43 Mar 9, 2009 04:52 PM
I agree, never heard of the .4xx lift 212/218...is this some kind of a custom grind or something?
sickREDsierra Mar 9, 2009 05:57 PM
nah.. he is just posting the wrong specs.
stock cam is almost that much. wouldnt be much point in buying a cam with 400 lift
QQuiksilverado Mar 9, 2009 06:44 PM
sorry bud but im not a retard those are the right specs. It gives the specs right on the box. And valve lift is .488 intake and .495 for exhaust. Thank's for everyone's help I'm going to get the right parts so I have no issues
sonoma43 Mar 9, 2009 06:50 PM
curious....why are you going with such a low lift cam?
QQuiksilverado Mar 9, 2009 07:00 PM
I asked for a cam that would give me some performance gain and thatI could tow my boat and race quads with. This is the cam that came up in the search. I wanted a 112LSA for the choppy sound also. That way it will sound nasty with my longtubes.
Phantom Mar 9, 2009 07:07 PM
whatever you do don't get comp 918s
