Valves closed..............
Old Jan 20, 2016 | 02:17 PM
Mark Johnson's Avatar
Default Valves closed..............
One more cam question, thanks for bearing with me; I'm trying to figure out the total time intake and exhaust valves are closed, do ya subtract EVC from IVC then subtact that from 360*? I can't seem to think............
Old Jan 20, 2016 | 02:43 PM
Atomic's Avatar
I have a gauge for that
Total time they are both closed, so basically the compression and power strokes?
Would be 360-(IVC+EVO)...
Assume IVC is at BDC and EVO is at BDC of the next stroke. That would be 360 degrees. The crank rotates twice for each cam revolution, and degrees are measured in crank degrees so a complete cycle is 720 degrees.
Real example is my cam at 0.05" of lift IVC is 46 degrees after BDC and EVO is 68 degrees before bottom dead center. Total time they are both closed is 360-46-68=246 degrees of crank rotation.
Old Jan 20, 2016 | 03:01 PM
Thanks- I was gettin' all lost in the math...........
Old Jan 20, 2016 | 03:05 PM
Atomic's Avatar
Why are you wondering about that time? Just curious...
Old Jan 20, 2016 | 10:03 PM
Default vales closed
Dreaming up a cam for when the day arrives to rebuild
Blt2tuk
Jan 9, 2016 11:19 AM
carid
Dec 30, 2015 07:40 AM
376c5vette
Dec 29, 2015 10:04 PM
CF7GO
Dec 29, 2015 06:01 AM
TAPyvehc93
Dec 28, 2015 08:28 PM
