valve seats and seals patriot dual spring kits
i have a 5.3 LH6 and befor i go in the cam swap process i saw that all valve seals have the same length ( i have the 8501 kit not the 8501-B) also the valve spring seats have two sizes wich one is right for me
the kit i have is this Patriot Performance's Xtreme spring evolved from our Orginal Patriot Gold. The Xtreme spring is for power adder applications, heads using large valves, and for aggressive cam profiles. These complete spring consists of 16 Patriot Gold dual springs, 16 titanium retainers, 32 Super 7 Machined locks, 16 .505" ID machined spring bases, and 16 viton rubber seals. This kit will work with both stock and aftermarket rocker arms. No cutting or machining of the stock spring pocket is needed. Patriot Performance's Xtreme spring evolved from our Orginal Patriot Gold. The Xtreme spring is for power adder applications, heads uses large valves, and for aggressive cam profiles. These complete spring consists of 16 Patriot Gold dual springs, 16 titanium retainers, 32 Super 7 Machined locks, 16 .565" ID machined spring bases, and 16 viton rubber seals. The larger ID spring bases are for use with bronze guides. This kit will work with both stock and aftermarket rocker arms. No cutting or machining of the stock spring pocket is needed. |
any one?
Originally Posted by sand man
(Post 4835407)
the kit i have is this and the 8501-B kit is will the first kit that i bought work or should i change any thing befor i start ? The larger ID spring bases are for use with bronze guides. |
Originally Posted by Suburbazine
(Post 4835849)
I quote your quote because it contains the answer:
lol im dumb i didnt notice that
how about the seals having the same hight on both intake and exhaust
(Post 4836158)
