-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   V8 SWAP couple of questions (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/v8-swap-couple-questions-561251/)
that_1_arkansan Aug 18, 2024 08:20 PM
Hey all, I’m new here, really gonna try to not make a thread that’s already been talked about but I’ve done some searching and don’t see anything too related. Yes, I’ve read the swap guide thread here. Found One person in a similar scenario, but the solution was to swap the long blocks only but I only have one v8 to go by.
so, I have a drive by wire 4.8 LS. It’s been a little project me and my dad have been building together. going to be putting it in a short wide ‘00 truck.
correct me if I’m wrong, but my options are either to A, go to the junkyard and get a drive by wire pedal with the module it attaches to
or B, get a drive by cable throttle body. This seems easier but the harnesses are different, right? Wondering what wiring needs to be modified if I go with a DBC intake swap rather than doing all the DBW conversion stuff.
i should mention I really want to keep it DBC. just prefer how that setup feels.
thanks for the help and point me to any helpful threads if I didn’t catch this question already answered.
joom Aug 19, 2024 07:26 AM
https://www.performancetrucks.net/fo...-guide-378643/
shakenfake Aug 19, 2024 09:02 AM
You just need to put the DBC throttle body on it.
Harnesses are the same for the most part. You don't need to change anything when using a 99-02 harness.
that_1_arkansan Aug 20, 2024 08:53 AM
I’m not sure what year the 4.8 came out of as I was given it by a relative, but seeing as it’s DBW it’s an 03-06. So what you’re saying is I just need to either buy or go to the scrapyard for a 99-02 v8 harness, and then hook it up to the 4.8 when it’s mounted in?
do I need a 99-02 ecu with the drive by cable stuff inside of it? I’ve seen there’s some differences where the newer computer doesn’t have the cable module.
shakenfake Aug 20, 2024 09:29 AM
The PCM that you have with your V6 will work.
Yes you need a 99-02 harness and fusebox and not the 03-06. It will make your life wayyyy easier
strutaeng Aug 20, 2024 10:54 AM
Is your V6 computer the 0411-style that looks like aluminum or the black box?
My 99 Silverado V6 had the black box, so I got the other style when I did my V8 swap.
that_1_arkansan Aug 20, 2024 01:18 PM
had to go outside and check it’s a black box
is there an advantage between the two?
that_1_arkansan Aug 20, 2024 01:20 PM
Yes that’s exactly what I want to do, make this as easy as plug and play, because I know I messed up picking this year truck with this newer engine but the engine was only $500 bucks from him and the truck was cheaper than what 03-07’s are going for. I like the bubble eye look a lot too! It already came with an HD conversion when I bought it.
shakenfake Aug 20, 2024 01:34 PM
Okay then since you have a black box you will need the PCM out of any 99-02 V8 truck. V6 will work as well you just need the correct one.
that_1_arkansan Aug 20, 2024 01:36 PM
okay I’ll add that to the junkyard run, just the throttle body, I need the v8 motor mounts and a 99-02 harness. And an aluminum 99-02 v8 PCM. Thanks dude.
