-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Upgrading mass airflow sensor (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/upgrading-mass-airflow-sensor-482286/)
MON_06 May 9, 2011 12:26 AM
I was looking in a new upgrade im looking at the maf sensor dnt know if i should do it or do somthing else?... I was reading it gives u 10-15hp to the rear wheel....any one have this upgrade and if so how do u like it and did u feel the power and what kind do u think i should go with or should i go with some other upgrade?? Thanx
GMCSIERRA5.3 May 9, 2011 12:29 AM
imo dont waist your money on that it doesnt help out..well it didnt on homeboys truck idk it felt the same
MON_06 May 9, 2011 12:42 AM
So ur saying its a waist of money then?...ur boy has one and didnt like it or what?
mhotrodscooter May 9, 2011 12:46 AM
If you have swap intake & tb to something bigger. I could see a reason behind it. If your still running stock stuff leave it be.
GMCSIERRA5.3 May 9, 2011 12:48 AM
yeah dont waist your money...he put the maf and spacer at the same time and the truck felt the same beofre and after..heres some good info hope it helps u http://rgvtruckperformance.net/rgvtr...ss+flow+sensor
MON_06 May 9, 2011 12:49 AM
Stock intake and tb but tb is p&p
mhotrodscooter May 9, 2011 01:04 AM
Your stock MAF is around 85ish & your tb is 78mm. So it's not going to pay to go bigger. Spend the money on some real power "cam" comes to mind. :)
Btw I like the paint job looks killer :thumb:
MON_06 May 9, 2011 01:17 AM
Im thinking nitrous i seen a kit for 4bills...im thinking a cam next yr
pasadenaman May 9, 2011 01:56 AM
X2 on waste of money. I pait about 350 for the granatelli MAF. It was junk and the oil from the K&N FIP II kit kept messign with the sensor.
On the NOS kit, just read up on how to stay legal with a N20 Kit. Cali has too many greenie laws.
IF it was me I would just go FI but thats 10X the amount your lookingg to spend.
oldred95 May 9, 2011 10:06 PM
The only time you need to replace the MAF is when it starts to become the restriction and I believe its good for somewhere in the 600 hp range. I had an idea the other day about using a duramax mass air sensor as it could be put into any size air tube going to the engine. It would most likely have to be rescaled to make it control the fuel correctly but it would no longer be a bottle neck in the intake.
