turbo install
Hello everybody. Im frustated that most shop are full schedule till JAN. Vegeance racing and Spartan performance are full till JAN. I start have no patience really want finish with my truck turbo install, fuel system returnless to return style with FPR and triple gauges pods hook up. Those all I not have some good experince. See if anyone who knowledge and performance install. See if can help me out. I will pay as well. Im from Buford GA please help me guys
Your to far from me man or i would help. What you have left turbo wise left?
Fuel system is easy. Take your bed off so you can have room to move around, could pull tank bit won't be a clean of install. Gauges what gauge you have to run? |
You need someone to install the fuel system and gauges?
I need do is install the trick kit stage 3, hook speed density iat, 2.5 map bar.
Fuel rail ebay, 80lbs injector, returnless to return style. Run Fpr regulator. Also walbro 450 Pump with Hotwire harness. Three aem gauges boost, fuel pressure, air/fuel ratio. That all I need to be done before tune dyno. I finished put in new motor built for boost and swapped to 4l80e as well. |
Originally Posted by Go5.3tt06
(Post 5318581)
Originally Posted by JordanH
(Post 5318630)
Drive it over here to west Texas, we'll have thing together in two days!
How you do that since need tuning and dyno. |
I can help pm me. Jon
I'm in Marietta.
Good news JMAYNARD72 JON is working on my truck since last Tuesday at his shop. Very well work. Still work on it. He is very helpful and always text me for every update.. When it get done I will take all pictures,.
| All times are GMT -5. The time now is 02:44 AM. |
