Transgo install
How hard is it to install the HD2 kit?
The HD2 kit includes internal parts. I have the HD2 also..so I have the same ? as white1
you have to remove tranny if i remember correctly.
Yep that's what I was told. That's the easy part.
I had that kit installed and they did not have to remove the tranny... I think the only thing that requires you remove the transmission is the highrev spring kit..
Its probably worth the 150-200 bucks to have a professional do it.. I have a very reputable transmission shop do I mine for 200... That included corvette servos, overdrive servos... and other misc. parts.. |
They did not have to remove the tranny for my install. I payed someone $150 to install my Transgo and Corvette Servo.
Thast about the same exact deal I had.....
I paid $1300 for my install. I will soon see if it was worth it as soon as I fix my broken rocker arm.
$1300.00 for a shift kit install :shocked: somebody ripped you off bad man :barf: The trans shop I use charges 75.00 and for any work that requires the trans to be removed (convertor or rebuild) its 150.00
i got quoted 400 for install w/o remove tranny...800 if remove tranny...not including price of kit
