transfercase
Old Mar 30, 2003 | 10:51 AM
bowtieboyz1's Avatar
Default transfercase
I have 37000miles and have been through 3 t-case adapters and just cracked another t-case is anyone else having this problem?
Old Mar 30, 2003 | 04:18 PM
silent1's Avatar
Default Re: transfercase
What is cracking in your t-case? I recently saw that I was leaking trans fluid from between the t-case and trans. What kind of symptoms were you having before they would give out?
Old Mar 30, 2003 | 05:04 PM
BigTex's Avatar
I don't know of anyone here who has really had any issues with the transfer case. Several of us are giving them hell too. I had to replace my motor / encoder, but thats my fault as I dropped it. What are your symptoms?
Silent1 - the transfer case is mated to the transmission through a transmission adapter. One side of the adapter is a pressure sealed fitting, the other has a gasket and teflon sealant. What side of the adapter seems to be leaking?
Old Mar 30, 2003 | 11:48 PM
silent1's Avatar
Big Tex, I was leaking trans fluid on the trans side not the tail shaft side. Wierd thing though, is that it hasn't leaked in a while and the fluid level is ok.
Old Mar 31, 2003 | 08:55 PM
The first thing i would notice is a leak. What i have been braking is the pice that goes between the t-case and the tranny that is also where the mount bolts also go. the t-case leaks right on the bottem i can see the crack. the first one i never saw the crack the dealership replaced it. the last time i broke the adapter it broke right in half while i was on the highway..
Old Apr 1, 2003 | 10:07 AM
Seeing Red Again's Avatar
HMMM...I'm only speculating here, but could it be the transmission and/or x-case mounts? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Maybe it jiggled loose and the shaking is breaking the case?
97aztecgt
Sep 10, 2015 05:07 PM
iregret
Jul 27, 2015 10:32 PM
1BAD73
Apr 12, 2009 07:23 PM
6.0caddy
Sep 26, 2006 09:13 PM
