-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Torsion bars? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/torsion-bars-180259/)
02PewZ71 Jun 8, 2004 04:08 PM
Torsion bars?
Anybody know if I can put torsion bars off of a LD2500 on my Z71? How much will it lift the frontend at normal adjustment of the bars? Will they fit in my lower a-arms?
cstchevy Jun 8, 2004 04:15 PM
I really don't think they would fit, they might, you might as well just crank your torsion bars up.
whitez71 Jun 8, 2004 04:30 PM
Yes they will fit and raise it maybe 1/2 to 1 inch. Check out this page for all info on torsion bars. http://www.fullsizechevy.com/forum/s...threadid=65871
02PewZ71 Jun 8, 2004 04:31 PM
Reason I am asking is because there is a guy selling a set on Ebay claiming he had them on his Z71 and I am wanting to lift my truck a little. My other option is torsion bar keyways, but I figure if the 2500 bars will go on , why not get the extra load capacity.
marc_w Jun 8, 2004 08:32 PM
I heard 2500 bars in a 1500 will actually DROP the truck? Something about them being keyed differently?
FLATOP08 Jun 9, 2004 08:20 AM
I show the bars the same for 1500 2500 3500. The differance is the load weight. It ranges from 4553# to 9054#. Check your vin for the code. The code will be like 7GG 6GG, 6XG 7XG.
whitez71 Jun 9, 2004 10:02 AM
Thats if you swap the keys, the bars will raise it some.
spearfish3 Jun 9, 2004 12:12 PM
I think you get "green keys" that raise your truck about 2 inches. I believe they are the same ones off of an f150 and they fit for some reason. I'm sure if you go to an alignment shop that deals with a lot of lifted trucks they could help you out.
whitez71 Jun 9, 2004 12:53 PM
The code is on the TB on a tag.
15712407 - Left torsion bar code WX torque 5826
15712408 - Right torsion bar code WX torque 5826
15528955 - Left torsion bar code gf torque 5826
15528956 - Right torsion bar code gf torque 5826
15712409 - Left torsion bar code Wy torque 5913
15712410 - Right torsion bar code Wy torque 5913
15528957 - Left torsion bar code GG torque 6790
15528958 - Right torsion bar code GG torque 6790
15528959 - Left torsion bar code GH torque 7161
15528960 - Right torsion bar code GH torque 7161
15712411 - Left torsion bar code WZ torque7267
15712412 - Right torsion bar code WZ torque 7267
15528963 - Left torsion bar code GK torque 8615
15528964 - Right torsion bar code GK torque 8615
15528965 - Left torsion bar code GL torque 8782
15528966 - Right torsion bar code GL torque 8782
15732338 - Left torsion bar codeXG torque 9054
The "green keys" are stock on 1500s, the are used to lift a HD. you use the ford keys to lift a 1500.
