Time to upgrade injectors??
Doing a dod delete with a new cam. Wanting to know if I will have to get the 8.1L injectors. Would like to know before I get it tuned.
comp cam 54-450-11 lobe separation 115 intake center line 111 duration. Intake 260 Exhaust 266 Lift. Valve intake .513 Valve exhaust .520 Lift. Lobe intake .302 Lobe exhaust .306 Basically a stock engine now and don't have any plans of making it a race truck. |
I would say no.
If your truck is flex fuel, the injectors are good up to about 10psi (if boosted). Since you're NA, don't worry about them. |
It is not a flex fuel. So I think that they are a little smaller.
Originally Posted by Jaa
(Post 5395932)
Either way, you should be fine. |
08 not flex
injector size 25 |
I would install flex fuel injectors or get larger ones just to be safe.
Here's a link for some 30s...
https://www.performancetrucks.net/fo...0681-a-547587/ I have 8.1L truck injectors in my LQ4. Last dyno, still had plenty of injector left. |
ctsv forum, LSA injectors, top hat hight and pigtail adapters from Ebay. under 150$
send to FIC, 250 for flow match to 1kcc |
