TBSS engine in 05 silverado
Old Jun 21, 2011 | 10:45 PM
262_NBS's Avatar
you will need a V8 truck harness unless someone has successfully repinned a tbss harness...... and drive-by-wire pedal assembly.
Old Jun 22, 2011 | 02:18 AM
chpspecial's Avatar
The TBSS has a 54x reluctor wheel, as well as the 4x cam sensor. So this is not a just drop in swap. Plus the sensors are in different locations. you will need to contact some one that makes the plug and play wiring harnesses, as well as swapping your v6 engine harness to a v8
Old Jun 22, 2011 | 07:25 AM
daytonayellaz's Avatar
The 06 TBSS is not 58x.... its 24x. 07 and up TBSS are 58x.
Old Jun 22, 2011 | 08:37 AM
50hexman's Avatar
ok... so i need a V8 silverado harness and what do i do about the sensors in different places?
Old Jun 22, 2011 | 08:39 AM
50hexman's Avatar
so then it will work with a v8 harness?
Old Jun 22, 2011 | 08:45 PM
50hexman's Avatar
Old Jun 22, 2011 | 08:58 PM
bigboy576103's Avatar
regaurdless of the little nick-naks that gotta be done should run like a prostetute runs from cops!!!
Old Jun 22, 2011 | 09:03 PM
rjwz28's Avatar
Man Motor club
Yeah it will definitely be fast
Old Jun 22, 2011 | 09:21 PM
262_NBS's Avatar
http://www.ls1gto.com/forums/showthread.php?t=193230
according to this thread there is a transition between 24x and 58x starting in 06
Old Jun 22, 2011 | 11:14 PM
Black sensor = 24x Right behind the starter solenoid in the block. Not trying to sound like a know it all but the 06 TBSS is 24x. This is a good thing for the OP!
