-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Sudden rough idle (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/sudden-rough-idle-492075/)
kode-x-kustoms Nov 15, 2011 06:00 AM
Sudden rough idle
Hey guys,
Like the title says, I have a 04 LQ4 (stock cam) and it has a new found chop at idle. It is like it can't make up it's mind if it wants to be cammed or stock. It only does it at idle and has not seemed to have lost any power. Any suggestions as to what it may be?
Thanks
kody
smokeshow Nov 15, 2011 06:13 AM
Sounds like an intermittent miss...tons of things could be causing that.
kode-x-kustoms Nov 15, 2011 06:48 AM
It does not seem to be a big deal it does not die, and it does not do it when you roll into it.
The truck is creeping up on 138,000 miles could it be something is going out with age?
kode-x-kustoms Nov 15, 2011 09:27 AM
Ok this is now getting interesting the truck just threw a code. I'm not sure what it is I will have to pull it when I get home.
