Stainless header and wraps
Old Jan 19, 2009 | 05:27 PM
CaptCameltoe's Avatar
Default Stainless header and wraps
I know this is the Chevy section, but not much goin on in the Dodge area. I am working on my magnum v10 swap into a half ton and have a new set of borla stainless headers that i stole off ebay for $100. I want to get them coated, but swaintech is just a little too pricey for me. Do you think there will be any problems with using header wrap on them being that they are stainless? I know the wraps kill plain old steel headers fairly fast, but i thought the stainless might not have this problem. Any ideas or thoughts? Bein in Sw Fla I really want to keep the underhood heat down as much as I can.
Old Jan 19, 2009 | 07:28 PM
POPO1984's Avatar
I was thinking of doing the same thing to my obx stainless on my chevy
Old Jan 20, 2009 | 12:36 PM
mxhotshot's Avatar
i wrapped a set of coated steel headers a few years ago and i never had a problem with them, sold the truck to my friend and as far as i know he has not had an issue with them.
the headers i wrapped where hedman elites with that coating they run
jake
Old Jan 20, 2009 | 06:13 PM
Thanks, sounds like I should be safe then.
Old Jan 20, 2009 | 06:53 PM
Mangled03gmc's Avatar
Baltimore Whore
Why would you want to get a stainless header coated??? If they are decent stainless, you will be fine wrapping them..
Old Jan 20, 2009 | 07:06 PM
To keep the heat in the header and out of the engine compartment. Swain tech coating is more effective at holdin the heat in the header, not just for looks which is pretty much all jet hot is good for. check it out, blows jet hot away as far as thermal efficiency goes.
http://www.swaintech.com/store.asp?pid=10969
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
13
Nov 5, 2015 03:31 PM
Stainless Works
Aug 7, 2015 10:08 AM
Stainless Works
Aug 4, 2015 12:56 PM
Ketis
Jul 23, 2015 12:37 PM
