Squeaks in my truck
Seams like I have a few new squeaks in my truck. When I'm outside the truck and shake it, it squeaks. You can here this inside when your driveing. Sounds like it's coming from the shocks or body mounts. Any greese points I try out.
Re: Squeaks in my truck
I also have squeaks in my truck. It sounds like they are comming from my rear Driverside door. If I take the inside pannel off, it gets quieter, but it still squeaks and I think that I am going to have to take it into the dealer to have them fix my door. The only way I can't hera it is if I play the radio or my CD's relativly loud. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I get squeaks too from the rears of both doors, as well as behind that plastic piece that is behind the seats (regular cab).
Truck was squeakless with 6000 miles in the dead of winter in the freezing cold. Now with 13,000 miles and warm weather it's developed lots of noises....ahhhh, GM build quality. |
My gas tank sqeaks bad when it has over 1/2 tank of gas in it. I took it two different dealers a total of 3 times and they couldn't fix it. Now I get to fix it myself since they are to dumb to do so.
Skid |
i just sprayed some wire cables the hold the body to the fram right under the doors under the truck .the sqeeek sounded like it was the seats
| All times are GMT -5. The time now is 12:39 AM. |
