Speed Engineering True Dual Exhaust Prototype..
Old 09-08-2017, 09:15 PM
  #841
Cammed_denali86's Avatar
Default Swapped mufflers
I swapped mufflers and went with the borla xr1 sportsmans, dont have any drone now. Its a bit louder but has a really deep growl to it. So far im liking it. Still used all the speed engineering piping too.
Old 09-11-2017, 10:50 AM
  #842
Former Vendor
Speed Engineering's Avatar
Clean looking setup.
Thanks
Sean
Old 09-12-2017, 10:38 AM
  #843
collins6.2's Avatar
How much louder are the borla mufflers? I really don't want the truck to be louder but if I can remove drone then I'd be alright with it. I've also thought about going with a 22inch magnaflow 5x11 dual in and out.
Old 09-13-2017, 11:25 AM
  #844
BIGRED811's Avatar
Any feed back from anyone using or modifying this to work on a Tahoe ? 07-13
Curious about drone
Old 09-14-2017, 10:56 AM
  #845
Former Vendor
From what we have heard our kits work on the SUV's as well. They just need an additional hanger welded.
Thanks
Sean
Old 09-20-2017, 09:01 AM
  #846
Dangrebel's Avatar
by the way, the axle dump kit for the crew cab short bed fit my 2000 ext cab long bed. I just had to add hangers. It clears the frame and supports just fine with the exhaust dumping about 2 feet before the rear axle. I love the tone and it sounds nasty with my stalled 408.
Old 09-21-2017, 02:17 PM
  #847
Former Vendor
Glad to hear. Thank you guys again..
Sean
Old 10-29-2017, 08:34 PM
  #848
Zach79Z's Avatar
Any test fitting on lifted trucks? Curious if you’ve had any issues with the drive shaft
Old 10-30-2017, 11:22 AM
  #849
Former Vendor
Suspension lifts are fine. Any larger lifts that move the front diff down will defiantly bring the front driveshaft closer to the Y-Pipe.
Thanks
Sean
Old 11-29-2017, 07:29 PM
  #850
100% Redneck
RedXray's Avatar
Received 1,329 Likes on 792 Posts
Any fitment issues with the tailpipes and the rear housing on a nbs rcsb 4/6 drop. Very little room between the bed and the axle. The tailpipes on my Gibson catback system wouldn't work. Had to have a muffler shop bend some tailpipes and as you know non mandrel bent pipes have a lot of restriction.
Quick Reply: Speed Engineering True Dual Exhaust Prototype..
