Spark plug gap, 2002 5.3 litre Chevy?
I have a 2002 5.3 litre Chevy. The book says the spark plug gap is to be .060 but the guy at the Chevy garage said he thought that there was a bulliten out that the gap should be .045.
What the truth? |
I gap my ngk's at .060". Runs smooth. As long as it keeps running smooth I'm gonna stick with .060".
It all depends which plugs you're using, and if you're N/A or F/I. Stock gap for the platinums is .060. The Delco Iridiums should be pre-gapped at .045. I keep my NGK TR55's at .055 which is straight out of the box. Alot of FI guys run NGK TR6's at .030 to .035 I believe.
Yup I just installed the TR55's tonight and they are pre-gapped at .055 which is where I left them. Runs pretty dam good too!
NGK TR55 are pre gapped at .059" according to the NGK part # key. The first 5 is the heat range and the second five is the gap. This series of plugs have a heat rating of 4 (hot) to 6 (cold) so 5 is in the middle and gaps of None = .039" ( ex TR6 ); 5 = .059" and 0 = .080".I noticed the TR6s I installed were a very loose .035" when I installed them but they were close so I left them. I tried adjusting one but it was a real pain for the small difference so I left the rest and adjusted the other one back to the factory setting.
i pulled my stockers out today to get ready for the radix and just for the hell of it i checked them... at 5000 miles....35 is what i got :nod:
I'm running AC's just like the stock plugs but with the Radix which is being installed now. Nelson tune to come after the Radix is up and running. Will Allen recommend a different plug maybe?
ngk tr6 at 35.spark will blow out on stockers.....
I believe Allen will recommend the NGK TR6 gapped at .035 along with most other people. I see that BigTex is using the Iridium IX version of the NGK and seems to be having good luck with them. |
