Small dig test
Old Oct 17, 2013 | 09:42 AM
BigDaddy0381's Avatar
Default Small dig test
just playing around, tune still needs a lot of tweeking I believe.
October 16, 2013 9:59 PM - YouTube
Old Oct 17, 2013 | 10:00 AM
Suburbazine's Avatar
I would imagine you have some power that's not being used in the tune, with all those upgrades. It could be the gearing and tires but it looked a bit like it was ******* the 2nd gear pull from 50-70.
Old Oct 17, 2013 | 10:06 AM
I started in 2nd and then it changed to 3rd around 50mph. Forgot to add that in OP. I do feel like it lacks as to what it could be.
Old Oct 17, 2013 | 10:07 AM
darnie's Avatar
Bout dam time! haha looks good man. everything checking out ok?
Old Oct 17, 2013 | 10:37 AM
03sierraslt's Avatar
Ya pretty sure that was 1st gear and it shifted to second or something is off.
I run 32.8" tires and 4.10's and I hit 3rd gear at 97mph.
Old Oct 17, 2013 | 10:48 AM
my read out said second shift to third, I'll do a few more this weekend and post them. anyone want to help tune this thing?
Old Oct 17, 2013 | 10:56 AM
Shifting at 6000 with a 80e and your gears and tires should be around the following wide open speeds not accounting for converter slip.
1-2 53mph
2-3 89mph
3-4 132mph
The shift in that video was your 1-2
Read out from what?
Old Oct 17, 2013 | 11:10 AM
The elm thing in the port. I watch things thru it. I do also know it need to raise the shift point to 6400 via recommendation from cam company. I guess it needs more work than I thought. dang I need a tuner. it might have dropped to first the more I think about it. My idle want to stall out when I stop at times. the timing jumps around from 5% too 30+% at adle and cruze.
Old Oct 17, 2013 | 11:18 AM
GREENSIERRA's Avatar
Truck looks like it's moving pretty good
Makes me want to put my LQ4 in
Old Oct 17, 2013 | 11:22 AM
I have no idea what that is, I also don't know timing % as that means nothing. Do you have tuning software? Who tuned it last?
