Size Of Muffler
Old Jul 11, 2005 | 08:56 AM
mrb04's Avatar
Default Size Of Muffler
To replace the factory i think i am going with borla xs muffler what size inlet and out let do i need thanks this is for a 04 5.3 rcsb
Old Jul 11, 2005 | 08:58 AM
white1's Avatar
3" should work fine, I think the pipe size is 2.75, so 3" should fit over the factory pipe.
Old Jul 11, 2005 | 09:00 AM
ap2002's Avatar
good choice of muffler, I have the same one
I got the 3"inlet/2.5"dualoutlet.....sounds good!!!
Old Jul 11, 2005 | 01:21 PM
Diablo666's Avatar
I wanna replace the factory muffler on my truck too, i have a 4.8 regcab do you guys have the part# for that bolra muffler?
Old Jul 11, 2005 | 09:37 PM
mrb04's Avatar
do i need a 3 inch in and a 3 inch out and does it need to be offset thanks
Old Jul 12, 2005 | 08:35 PM
jerome's Avatar
center in to offset out. 3"in/out just go lay under your truck for five minutes and you will have all the answers. you need to get 2.75 to 3.00 converter if you plan on clamping. weld...you just lay alot of metal on and it'll be fine i guess. even if you get offset it will be off a little, so very hard to clamp. so if you can weld go right ahead and weld it up. the play will give you enough to connect. if you cant then i suggest you take it to a shop and have them do it.
oh yeah...this is all if you want to keep stock tailpipe..if not then dont worry about any of what i said
Old Jul 12, 2005 | 10:01 PM
white1's Avatar
I just ran 3" from the collector flange back
Superman09
Sep 25, 2015 05:55 AM
Cakes
Sep 6, 2015 02:57 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
