Reset computer
I took of the - post and even pulled and PCM 1 and 2 fuse and the ECM fuse.
The truck Remembers all the radio stuff but is it relearing the motor stuff now? Btw everything was pulled for over 1.5 hours. |
i think you have to do this with the key on. Reinsert the fuses with the key on as well. You will here the fuel injection reset.
The 03+ trucks are different. There is a little different trick, something like pulling the negative batt cable, then turning the ignition to start for 15 seconds or something like that.
| All times are GMT -5. The time now is 03:54 AM. |
