-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   pulled the 4.8. (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/pulled-4-8-a-429958/)
nonnieselman Dec 1, 2008 10:57 PM
get one of those lil cameras and look thru the spark plug hole..
and like they said look at the crank..
00Silv4.8 Dec 1, 2008 10:59 PM
and correction, the 4.8s are also an aluminum block.
So like nonnie said.. hope they're an honest person. When I sell my 4.8 Ill even show them the vin on my truck to verify if they want. I kinda got screwed on my 6.0 but Im getting it taken care of
hirdlej Dec 2, 2008 06:44 AM
Take a screwdriver and stick it in the spark plug hole and feel the piston. Start at the edge and go across. If you feel it dip after about a 1/2 inch it's a 5.3. If it never dips then it's a 4.8
StrokerAce03 Dec 2, 2008 04:42 PM
They never made a 4.8 aluminum block; they did make a 5.3 aluminum block though.
NateZQ8 Dec 2, 2008 06:47 PM
You could look for the VIN of the truck the engine came out of........other than that.......pull the heads.
Bo185 Dec 2, 2008 06:53 PM
Pulling the heads wouldn't always work. I though some of the later iron 5.3's were flat top as well 06-up??? Pull the pan look at the crank to be sure if you don't have the VIN.
X2 no aluminum 4.8's
litreddevil Dec 3, 2008 08:59 AM
most of the time their is a mark on what ever the motor is like a circle are a slash throught the number the block is.i really don't think anyone will be able to just pull a oil pan and look at the motor and say oh yea it is a 4.8 are yes it is a 5.3.
nighthawk08 Dec 3, 2008 09:02 AM
if you pull the heads you could measure the stroke pretty easily. best way to tell.
2manycars Dec 4, 2008 10:40 AM
+1 :nod:
Mark Johnson Dec 4, 2008 12:07 PM
How much oil can you fill the cylinder with? That'll tell ya the volume of the cylinder and which motor yer dealing with..............
