-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   pulled the 4.8. (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/pulled-4-8-a-429958/)
GMCDee Dec 1, 2008 10:06 PM
pulled the 4.8.
Just was curious does all 4.8 always have both the 4.8/5.3 on the back of the block. I just pulled what i think to be a 4.8 but it has both 4.8 and 5.3 on the casting on the back of the block. Just a curious.
Bo185 Dec 1, 2008 10:10 PM
All the 4.8/5.3 have this the 6.0 just says well 6.0.
What are you doing with the 4.8L?
charcold-bowtie Dec 1, 2008 10:10 PM
same bore anyway..
GMCDee Dec 1, 2008 10:12 PM
Nothing as far as i know probably clean it up and seal it up but no plans forit right now.
silveradol33 Dec 1, 2008 10:14 PM
block is the same for a 4.8/5.3 thats why it says that.
GMCDee Dec 1, 2008 10:18 PM
Gotcha :usa:
blazinblue Dec 1, 2008 10:38 PM
And how can you tell if its a 4.8 or a 5.3? by the head casting number right?
00Silv4.8 Dec 1, 2008 10:41 PM
by the crank. 5.3 is the same bore just a longer stroke. I guess no real way to tell unless you crack it open from my knowledge. I believe the 4.8 and 5.3 both can come with the same heads?
StrokerAce03 Dec 1, 2008 10:41 PM
4.8's have flattop pistons and a shorter crank; visually that's the only way to tell, and the heads are the same. Although the L33 5.3's have flattops too I think but they're aluminum blocks.
A Low Dime Dec 1, 2008 10:49 PM
So hypothetically speaking, if you were buying a motor from someone, and they claimed it was a 5.3. Without tearing into the motor, how could you tell if it was a 4.8 or a 5.3?
