Pac springs
I would say around 6500 Rpm with an 1.800" Installed Height. They have a max lift of .625. I don't know if PAC actually lists a Max RPM on springs since there is so many variables that can affect that.....Cam Lift, Duration, Valve Weight, and so on.
I have run the 1218's up to 6500 rpm, but usually have my shift RPM set at 6,300 rpm using a small 212/218 .552/.552 113+2 Cam. I am using C5Z LS6 Hollow Stem/Sodium Filled Valves in my 243 heads. I am also using the PAC-R511 Titanium Retainers and Machined Valve Locks to keep my valvetrain as light as possible.
turboal1 (07-27-2018)
A Low Dime
08-11-2009 11:06 AM
Silvy6.0
04-16-2009 07:57 AM
Stangkilr
10-13-2008 10:39 PM
