(Post 5453272)
No way in hell that is correct.
Originally Posted by smokeshow
(Post 5453276)
The only thing CFM is good for is measuring flow rate over Niagara Falls.
IMO keep the heads and cam do exhaust. Fuel for E85 if possible then pulley.
Originally Posted by ZO6Ted
(Post 5453284)
Here's another thought I had on-the-fly.... As I mentioned, I have a Volant CAI with the Volant snorkel, feeding through the stock MAF to the Magnuson air tube and a NW 90mm TB...again, the Radix j-tube is untouched. I was thinking about swapping in a Banks Duramax Ram Air box, modifying the Banks 4" intake tube (heat with a PVC pipe heater blanket and bend to shape) for proper alignment with the Radix j-tube and putting a getting a 100mm MAF in between. Could get the j-tube ported and modified for a 102mm TB as well. Doing the math in my head, that's probably around $1400-1500 with the TB & MAF purchase...sounds great except the $$$, I think that one won't be getting past the mental drawing board. https://cimg7.ibsrv.net/gimg/www.per...29fd141b38.jpg |
Are you DBC or DBW throttlebody?
A couple problems.
First your ECL is 115 Second, your VE is 100, not 1. Also, at 10 psi I would have said 165 (10 psi is about 65% of atmospheric pressure on top of an atmosphere... confusing. whatever... just do it.) The diameter I get is 1.92" with a length of about 40". |
(Post 5453295)
A couple problems.
First your ECL is 115 Second, your VE is 100, not 1. Also, at 10 psi I would have said 165 (10 psi is about 65% of atmospheric pressure on top of an atmosphere... confusing. whatever... just do it.) The diameter I get is 1.92" with a length of about 40". Fortunately Santa knows that I've been good this year, and he's working on a very nice set! :D https://cimg9.ibsrv.net/gimg/www.per...6d597576cd.jpg https://cimg6.ibsrv.net/gimg/www.per...e830ab3edf.jpg |
I really appreciate you guys' input...the exercise is educational and body checks assumptions that I tend to leap to when left to my own devises. After I get the 4L80e in, I think it would be very interesting to do a new baseline dyno then upgrade the exhaust and tune it on the dyno to see what was changed (gains/losses) in the HP & TQ curves. So, unless WWIII breaks out, that is the plan...exhaust with no other changes.
I guess the 3" collectors requirement precludes the 2.5" duals out the back. You guys mentioned both dual 3" and single 4"...is there a technical/efficiency advantage, or does it boil down to space and cost? |
Dual 3” and single 4” flow almost the same. Comes down to preference for the most part. |
Another variable you need to add back to your HP is blower drive loss.
558 HP plus divided by .8, and then add another 80 from the blower (just a guess). You are moving the air needed to make closer to 750-775 crank HP. |
(Post 5453376)
(Post 5453384)
Another variable you need to add back to your HP is blower drive loss. 558 HP plus divided by .8, and then add another 80 from the blower (just a guess). You are moving the air needed to make closer to 750-775 crank HP.
