oil on spark plug threads
Old Jul 7, 2010 | 04:25 PM
mudaholicZ71's Avatar
Default oil on spark plug threads
truck has been hesitating and have a slight miss while driving. pullled the spark plugs and noticed they had oil on the threads?? Once when i pulled my intake manifold off it was full of oil. could this be the problem? also sometimes at first start it blows out white smoke which im assuming is associated with the prob as well.
Old Jul 7, 2010 | 08:28 PM
budhayes3's Avatar
PT's Slowest Truck
The oil in the intake is from the PCV system, the GENIII engines suck a lot of oil through the PCV into the intake. An oil catch can in line with the PCV hose will help prevent that. I doubt that this is causing your misfire though.
White smoke is an indication of coolant, oil burns blue...if you're getting white smoke on start up, it could be from a leaking head gasket or cracked head, or if it's just a little puff, it may be normal condensation in the exhaust.
Your miss/hesitation could be caused by a number of things, fouled plugs, bad wires, clogged injectors, partially clogged fuel filter, dirty MAF, engine mechanical problems, engine control issues, etc. Start with the basics, fuel, spark and compression, and go from there. Check for any codes stored in the PCM...is the check engine light on?
Old Jul 8, 2010 | 04:34 PM
no check engine lights. maybe i need to check the MAF sensor. the plugs and wires only have about 20k on them. are the MAF's known for going out even with dry filters? whats the best way to check the MAF?
Old Jul 8, 2010 | 06:44 PM
neilownz's Avatar
Spray it down with maf/electrical sensor cleaner.
Most of the time over oiled k&n etc filters cause that to become dirty.
Fast86z
Aug 23, 2015 12:35 AM
rojeho
Aug 8, 2015 07:20 PM
Ketis
Jul 23, 2015 12:37 PM
wheeliE-maxx
Jul 19, 2015 05:37 PM
sTNT971
Jul 16, 2015 12:39 PM
