-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Oil pump primer? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/oil-pump-primer-511833/)
way2much_01 Dec 16, 2012 10:01 PM
Oil pump primer?
What is everyone using to prime the oil pump? Only thing I can find is distributer primer do they make anything to prime ls motors?
asap216 Dec 16, 2012 11:04 PM
as far as i know you cant do it manually.
james8997 Dec 16, 2012 11:16 PM
Pull the plugs and use the starter till it reads oil pressure
Ferocity02 Dec 17, 2012 12:54 AM
Pull the plugs, unplug the coil packs, and pull the fuel pump relay, then crank the motor. It should build oil pressure this way without starting.
oakley6575 Dec 17, 2012 02:00 AM
:cheers:
TXSZ66AVLANCHE Dec 17, 2012 06:01 AM
Just fire it up, I've done all mine like this and never a problem.
way2much_01 Dec 17, 2012 01:00 PM
Cool never thought of that
1Bear Dec 17, 2012 06:11 PM
I would probably just pull the fuel pump relay and unplug the coil packs, but as per the quote from Moregrip below posted back in '07, yes there is a tool available:
Originally Posted by moregrip (Post 3739779)
anyone use one of these to pre-lube their engine?
http://img.photobucket.com/albums/v6...dix/1610_1.jpg
GM
New engine prelube tool. General Motors has recently developed an engine prelubrication tool with its tool supplier, Kent-Moore. The preluber consists of a 2-gallon container, hand pump, flexible hose, adapter set and an instruction sheet. Properly used, the tool injects clean engine oil into the lubrication system, helping to prevent dry starts on new, remanufactured or overhauled engines.
Following the instructions included with the tool will allow the main bearings, connecting rod bearings and oil pump to get a healthy dose of lube. Use more than the minimum recommended amount of oil and the cam bearings and other valvetrain components will also be lubricated.
1969x11 Dec 17, 2012 08:38 PM
Just start it up...it will build oil pressure just like when you do an oil change.
02_Orange_D1SC Dec 17, 2012 08:52 PM
i used a cheap garden sprayer from home depot worked like a charm
