Oil Cooler installed, slight drop in oil pressure...questions
14 Second Truck Club
I have a 383 LS1 in a 99' silverado. I just bought the engine oil cooler lines for the engine oil cooler that is integrated into the new radiator (05+) I just bought. The motor has a FMS ported LS6 oil pump. I run 10W-30 Royal Purple.
Before the oil cooler, the oil pressure at idle (hot) was an even 40psi and at 6000rpms right at 60psi.
After the oil cooler, the oil pressure at idle (hot) is around 33-35psi and at 6000rpms 50-52psi.
I'm debating on what to do to raise the oil pressure. I'm sure I probably need to shim the oil pump just a little bit, but really don't want to do all that right now. Could changing the oil/brand bump it up some? It seems like the royal purple thins out or something when it gets hot.
Any input would be appreciated! Thanks!
what they said... by the way, RP does run a little different from other oils that i've used.
ignore the guy above me by the way. don't switch to dino oil from synthetics; bad idea
D1SCSS
01-25-2016 10:14 PM
Noah Burns
09-07-2015 05:50 PM
ullose272
11
07-17-2015 07:22 AM
