Official NBS V6 to GENIII V8 swap Guide
Old 04-11-2019, 09:38 PM
  #301
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by Cjcars
Looking for part numbers for the frame to mount bracket 2wd 2007 classic 4.3 to 2002 6.0 swap I ordered mounts from GM that the dealer thought was complete but didn’t include the frame to mount bracket
See Post 166 and then again in post 283.
Old 05-14-2019, 05:32 PM
  #302
Little_Mata's Avatar
Default Motor mount question
Is there a difference between the 4x4 and the 2x4 motor mounts or are they both the same?
Old 05-14-2019, 07:07 PM
  #303
100% Redneck
RedXray's Avatar
Received 1,329 Likes on 792 Posts
The frame mounts are different on GMT800's
Old 05-14-2019, 07:53 PM
  #304
Thank you for the reply. I understand the frame mounts are different however I am wondering if the motor mounts that connect to the block are different from a 4x4 and a 2x4
Old 05-14-2019, 08:49 PM
  #305
1FastBrick's Avatar
the actual motor mounts Should be the same.
Old 05-15-2019, 02:01 PM
  #306
100% Redneck
RedXray's Avatar
Yep...
I'd stay away from aftermarket motor mounts (like Anchor) as some headers brands (like Speed Engineering) have clearance issues because the aftermarket mounts tend to sag a bit right out of the box.
Old 05-16-2019, 11:59 AM
  #307
Ge14's Avatar
I did a swap on my 2003 Silverado. Did everything mentioned on this post. But my rpms are crazy. 3k on 60mph. Left the v6 tranny with the 5.3 flex plate. Was reading something about a spacer needed. Any help ?
Old 05-18-2019, 12:04 AM
  #308
100% Redneck
RedXray's Avatar
No spacer needed. You may have a shifter cable issue but it sounds like the trans cant find 4th gear. Count the shifts to make sure you're in overdrive. The V8 crankshaft will turn the same RPM's as the V6 if the rear gear ratio is the same. Make sure the tow/haul button on the shifter is not activated either.
Old 06-01-2019, 07:33 AM
  #309
Registered User
Elinar06's Avatar
Default Fuel line
Anyone have pictures of their fuel line set up?
Finishing up a 5.3 5 speed and this is my last thing to do.
Old 06-01-2019, 11:22 PM
  #310
makes children cry
_zebra's Avatar
i at least used to in my build thread (maybe in this one, too)
i'll look...
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
