NOS is in!!!!!
Well guys It's finally all in there I dithced the dry nos kit in favor of a wet shot of NX, I love it, I just have 2 questions I hope u guys can answer,#1 It seems to want to periodically shut down now this is only my 2nd day with it but is it the fuel pressure, I have a safety swith, it seems to do it at high rpm's? If I need a fuel pump where is a good place to get one??? Also what do you guys think it will run now I'm using a 150 shot 33 fuel and 62 n2o?
Re: NOS is in!!!!!
Cool!! Why did you dump the dry kit? How does the wet kit hook up? Does it have a fogger nozzle or a spacer plate?
Re: NOS is in!!!!!
Just has a fogger installed into the intake, the other kit I just didn't feel right about the tee in the fuel injection vacuum left me somewhat scared to push the button, also I heard the torque with the wet kit is off the hook they are right!!!!!!!!
Re: NOS is in!!!!!
You interested in meeting up @ Carlsbad July 29th? I know its a trek from Bakersfield but I already have a few other truck board guys meeting up that day. Let me know...and glad to hear you are happy with the NX.
Richard |
Re: NOS is in!!!!!
You might want to autotap it. I have two sets of directions for the NX kit. One says use the 33 fuel pill, another says use the 35 fuel pill for a 150 shot. Don't let it run lean. Ask FAST 4.8 about running lean and why his nitrous isn't hooked up right now. If you think you are dropping fuel presure, back it off to a 125 shot and see how it runs.
That NX torque kick A$$ doesn't it! |
Re: NOS is in!!!!!
Oxidizr did your rwhp go up? Why?
Re: NOS is in!!!!!
the torque is awesome I love it!!!!!!!!Give me directions to carlsbad and I'll let you know how far is it and what times do you think I can expect? I'm guessing like a low 13 is that to low????
Re: NOS is in!!!!!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by rphinney:
<strong>the torque is awesome I love it!!!!!!!!Give me directions to carlsbad and I'll let you know how far is it and what times do you think I can expect? I'm guessing like a low 13 is that to low????</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It is off the 5 freeway in before San Diego, forgott what street you get off at though. I am sure someone else knows. If you go, I will most likely be down there, hopefully with a new tranny and some more mods. Kent. |
Re: NOS is in!!!!!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Oxidizr did your rwhp go up? Why? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes. I up'ed the nitrous jetting to a .064 and to make up for the parasitic loss of the 4.10 gear swap.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> the torque is awesome I love it!!!!!!!!Give me directions to carlsbad and I'll let you know how far is it and what times do you think I can expect? I'm guessing like a low 13 is that to low???? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Low 13's is not out of the question with "reasonable" traction. This will not be too easy with a suspension drop and 18's. The 18's alone add quite a bit of unsprung weight and your tires are not going to give much before spinning. Asuming you are able to keep you 60ft under a 2.3 you have 13.1-13.5. Anything above a 2.3 and it'll depend on have fast you can recover with the nitrous. </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">It is off the 5 freeway in before San Diego, forgott what street you get off at though. I am sure someone else knows. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">5 south to Palomar Airport: map Richard |
Re: NOS is in!!!!!
The truck does not do to bad as far as traction goes. I have the nitrous on a button inside the truck , not WOT switch. So I can nail it out of the whole the tires break but only momentarily then at 3000 rpm I get on the bottle as long as it isn't to hot out the tires won't break loose but one time they did and all the way thru 1st gear <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> What about letting some air out of the tires does this work????if so what PSI would you reccomend, I have 255/55's. I would love to meet up with some of you so cal guys I'll keep you posted <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
