-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   NGK TR6 for 10.5:1+ compression? (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/ngk-tr6-10-5-1-compression-441774/)
GMCtrk May 26, 2009 08:49 PM
Does anyone know if the TR6 is a better plug for me than the TR55's I have in there now? (actually 7 TR55's and 1 stock plug because I dropped one of the 55's when installing).
Mangled03gmc May 26, 2009 09:38 PM
I dunno if it is a better plug, but it is just a heat range cooler..
ZR1 DREAMING May 26, 2009 09:44 PM
Stick with the 55s for that application. It's NA correct?
GMCtrk May 26, 2009 10:38 PM
yes it's NA. I've read the tr6 is better for high compression. Im having detonation probs
ZR1 DREAMING May 26, 2009 11:20 PM
If you're having detonation I'd adjust your tune prior to resorting to plug swap. FYI, 10.5:1 generally isn't considered high compression really. I mean it's technically above norm but not to the point of worrying about heat range of plugs.
I'd say diagnose your tune and you'll be able to solve your issue.
What exactly is the build of your motor? Incl sizes and specs.
Mangled03gmc May 26, 2009 11:34 PM
This is true, as far as the tune goes.. I am running tr55's along with about 10-1, have FI with 0 issues of det...
TXsilverado May 26, 2009 11:43 PM
tr55...im at 11.0:1 with tr55's. check the tune
GMCtrk May 27, 2009 12:00 AM
alright thanks guys....Ive got a lot of problems...this is just a thought since I still have that 1 stocker in there....I think it's the original 2000 plug but im not sure. Anyways, I turned the MAF off a while ago (running SD) floored it and the truck bogged so bad @ 4000 rpms it's just stopped pulling....shitting all over itself, felt like a 4 banger. Plan is to change the intake manifold and TB gaskets, put new plugs in (ill go with tr55's again, but this is why i was asking, would it hurt to go with tr6's?)....then hopefully get this turd running right and then puts the new trans in.
Regarding the compression i asked a member on tech to calculate for me with his program (takes into account variables that you cant do on the general online calculators) and it came out to 10.63:1. But I also had a lot of carbon buildup on my pistons which I'm sure is raising it more and causing some hot spots on its own. Should have cleaned that off I suppose....
krambo May 27, 2009 07:54 AM
I am 11.5:1 and run the TR-6 plugs. I started with the 55's however swapped out to the TR-6's in prep for spraying at a later date. In N/A form, I saw no difference in the amount of spark advance I could run, KR observed and overall running condition of the motor between the two heat ranges however this was during winter months...the heat of summer may change things.
GMCtrk May 27, 2009 01:50 PM
Im gonna put the TR6's, I don't think it will hurt.
