NGK plug heat range?
10 Second Truck Club
Someone posted a heat range chart for the NGK plugs and the part numbers a while back. I have searched but can not find it now. I want to go at least one step colder than the TR6. Can't find it on NGK's site either. Can anyone help.
Theres not an actuall plug called a "tr7". The next colder plug than a tr6 would be part number R5671A-7 stock number 4091 which has a compression gasket seal on it, but will work fine with your heads. This is a cold plug and will kill you n/a. I dropped .2 tenths of et running n/a with this plug
Talked with a tech guy at NGK. He suggested I try a BR7EF, stock #3346. Said it was 1 range colder than the TR6 with full ground strap but recessed porcelain. I'm going to try these with 2* less timing and little more fuel.
Tydriver
45
Oct 23, 2015 09:19 PM
Shotguntommy
Sep 15, 2015 05:24 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
