Need some serious help on Torque Converter decision
I have been contemplating about putting a torque converter into my truck.
I have read just about every post in here about converters, and I am still unsure on what would be the best converter for my truck needs, or even if I should stick with the stock converter. I have heard so many people say go with a 3000 stall converter, but thier trucks are 2WD and do not tow anything. I have been thinking of getting a Yank or Precision Industries converter Can anyone help me answer a few more torque converter questions to help me decide what to do???? First is my vehicle info: '03 Silverado 1500 Ext. Cab Long Bed 4X4 5.3L 4L60E tranny 3.73 gears Mods: K&N FIPK Gen II PCMforLess 91 octane tune Magnaflow muffler Future mods: E-Fans Cam E-water pump shift kit and billet servo Vehilce Usage: Daily Driver will occasionally tow a small aluminum fishing boat in the future (16' - 18' aluminum Bass Tracker type boat) Or tow a small utility trailer with riding mower on it. I will be installing the shift kit and billet servo prior to any converter install. Here are some of my questions: What stall size would be best for my truck and truck usage? 2400? 2600? 3000? Should I upgrade to a better tranny cooler or will the stock one be ok? Is there any problems with getting a converter for 4 wheel drive truck? Is there any daily driving problems with a higher stall converter? How will converter effect towing the items I listed above? Will it be a problem? Any help in helping make the correct decision for my truck and truck usage would be extrememly appreciated. I have been contemplating this for a month now and still have fears of which one or if any at all. |
Not sure what brand... but nothing OVER 3000 stall for your setup... It will actually help with towing... and it will be fine for a daily driver... Tranny cooler should be fine, depending on mileage, maybe you should change it...
There are a few on ebay... they of course are cheaper... doesnt mean they arent good quality.. but summit has them.. jegs is probably one of the better places... not sure what brand tho.. someone will be able to tell ya |
Hey Man Im In The Same Boat. I Have Been Looking And Reading But Still Cant Decide. I Think It Would Be Best To Get Something A Little Less Than 3000 Maybe A 2800 Or 2600 For What You're Gonna Be Doing. I Would Definately Change The Tranny Cooler Its Only About $50-100. A New Tranny Is $1200-1500! But I Am Leaning Towards A Yank But They Are So Expensive I Dont Know. Sorry I Couldnt Be Much Help.
Thanks for the replies. I think I am leaning towards a 3000 stall.
Anyone else care to comment?? |
I think the small trailer your towing would have little effect on your stall decision. I have been thinking about a stall but I tow a steel flat-bed trailer with a race car for long distances that have large hills. I think 2600 would be the max for my situation...
Good Luck |
For what you are towing i would think you would be ok with a 3000 stall.. I decided on a 3000 because i wont be making that much power.. I think i would have been dissapointed going with anything less than a 3000.. It didnt take long at all to get used to and it is just flat out fun... Also yank and precision arent the only companies out there that make converters.. A lot of guys around here including me are running TCI converters and are having real good luck.. You can pick one of these up fron a sponsor ----------->
for 420-450 range.. The Tci is a smaller converter.. 10" vs the yank which is a 12" so it doesnt retain the towing capability that the yank does but once again i think you will be ok towing a small boat or utility trailer.. |
Really depends on what your gonna do with the truck. How often will you be drag racing at the track? Seems like you want a mild setup kinda like what I have. I used to run a P.I. 2800 which was very agressive at the track but had no towing capacity. I need to tow things every once in a while so I replaced it with a Yank TT3000. Full towing capacity and not annoying to drive. Seems like something you should look into. I haven't hooked up to anything yet but i'd bet it pulls easier(accelerates with less strain). A stock tranny cooler would be fine in this case unless you pull really heavy loads. Whatever brand stall you go with, make sure it can suit your needs.
Woo Hoo!! 300 posts :hump:
I think you would be happy with the TT3000 I know its exspensive but I think its probably what youre looking for.
I have the Yank TT3000 and I like it alot, driveability is great, it seems like the Yank converters are a little more tow/daily driver friendly than some of the other brands but they are more expensive and don't perform as aggressively at the track so I'd get the Yank 3000 if I were you
