Need some motor help....
I am in a dilema....I want to do a motor swap
Local performance shop.... I provide block crank covers cam They will bore a 6.0 .30 over Forged eagle H beam rods ARP everything Mahle nitrous pistons Polish/turn crank if need be Slide the cam in for next to nothin assemble all covers/assesories I give them For 2650 or if bearings need ot be lined? 2950 Option 2...... Iron block ls1, 5.3l bored to 5.7 with hyperautic crank and rods forged mahle pistons arp bolts assembled long block just about any cam I want Comp springs(918's) give me 500 for my core motor want about 26-2800 then give me 500 back when they recieve my motor. Keep in mind if I go option one I still have to buy block, crank, cam, covers/assesories, and maybe more. Thanks ahead of time. |
Go with the 6.0l. You will be more satisfied with that than you would be with the 5.7. Also you will have better rods for about the same money. How much are you going to spray, and are you planning on using the stock crank in the 6.0l?
I will not have better rods for about the same.
The 6.0 will cost about 1000 more. Yes stock crank on both motors. I can have forged rods put in the 5.7 for a little more money. |
Are they I-beam or h-beam?
Well, i forgot you have to still buy a 6.0l block......the 5.7 would definetly be cheaper.....you could buy better heads for the price difference in the two motors.
alright well spent alot of time on the phones.
I am going to go with the 5.7l wiht h beam forged rods, arp bolts, head studds, dart heads, any cam I want, 918 springs, mahle pistons, hyperautic NOT cross drilled crank, For about 2850. |
The first option you list with the 6.0L seems way over priced to me. An entire Eagle stroker assy, balanced, can be had for $2k. If all they are doing is providing rods, pistons and a build, $2650 sounds like too much.
You can get you block bored .030" over for under $300, Mahle pistons cost around $500, rods are not too expensive either. I paid a performance shop $500 to build my motor. Whomever you use, go with the stroker crank. You'll be wishing you did later, IMO. Like I said, the entire Eagle assy . (stroker crank, pistons, rods, balancing) can be had for right at $2k. If you're on a serious budget constraint, I guess it's a moot point. |
Nah dont really wnat a stroker motor at this point.
nobody else?
What are your overall goals for the truck? Daily driver/weekend warrior or perhaps a race only setup. Are you planning on forced induction of some sort? I've been really happy with the 6.0L, and your option 1 looks almost identical to my future setup. Let's hear what you want your truck to do for the most part. :burn:
| All times are GMT -5. The time now is 09:21 AM. |
