NEED HELP--ANY IDEAS WILL HELP
Old May 10, 2003 | 06:24 PM
one03sierra's Avatar
Formerly one92rs
Default NEED HELP--ANY IDEAS WILL HELP
WELL I WENT TO THE TRACK LAST NIGHT AND WAS VERY DISSAPPOINTED. MY MODS ARE LISTED BELOW AND I CANT EVEN BREAK THE 15'S.
60--2.45
1000--13.46
1/4--16.13
60--2.43
100013.73
1/4--16.34
REMOVED GRANATELLI-SCU2000. INSTALLED FACTORY MASS AIR AND RESET COMP.60--2.40 1000--13.26 1/4--16.03 IT SHOULD BE RUNNING A LOT BETTER THAN THAT IN MY OPINION. MAYBE I AM WRONG. LET ME KNOW WHAT YOU THINK.
Old May 10, 2003 | 10:04 PM
LS1TECH Sponsor
Default Re: not running right at the track
He doesn't have a denali only the front clip. But have you purchased a predator yet denali???? That programmer made the largest difference out of all few mods i've done.
Old May 11, 2003 | 09:45 AM
Formerly one92rs
no i havent had a chance to save up the money but i think i am going to go that route. maybe that will help the top end. i am telling you it falls on its face in third.i shifted into third at 79mph and finished at like 83 on first run and 82 on the second. i am trying to find out if the programmer will help that or not.or if i need to see if there is something else i ned to look at first.
Old May 11, 2003 | 10:39 AM
rgvsierra's Avatar
Default Re: NEED HELP--ANY IDEAS WILL HELP
82 mph on a modded 5.3 isint common, infact it is unheard of, most stock hit 87 and above. What track was this at in texas?
Old May 11, 2003 | 01:30 PM
sleepersilverado's Avatar
First off what gear are you running? Sounds like a 3:42? In reality when you are running 1/4 mile you want to end the 1/4 at the top of 3rd gear. Also were you spinning? I would think you were not with mph. Also have you ever tryed shifting your truck? that will also help if you have not tried it.
Ryan
Old May 11, 2003 | 03:42 PM
Hit Man X's Avatar
Well are you launching off idle or brake torquing? Any wheel spin?
Also, if the mufflers you are running are like what I am thinking of (totally empty internal like a coffee can) those bullets give you no low-end torque at all due to no back pressure...sure they are loud but what fun is being loud and slow? They are made for a Turbo/SC application or extreme N/A. I'd bet with an actual large cased muffler (Dynomax, Magnaflow, Flowmaster) you would pick up some time and power there also.
A programmer would get your WOT shift points up, raise the rev limiter, and add some timing. If you are gonna stick with bolt-ons, I'd go with the Diablo Predator. Its a great piece. Tons of features for the money.
Old May 11, 2003 | 06:04 PM
Formerly one92rs
yay it is a 3.42.houston raceway park is the track. and no i was not spinning-i had a buddy filming me to see just that.it will pull great in first and second.power brake take off.once i get to 1900rpm it will pull hard to5600 until i get in third.right now i have put on the factory mass air. i found that one of the ngk plugs was black on two cylinders. one plug wire-very back passenger side had rubbed through on heat shield.installed new autolite double platinum plugs-new msd wires-removed jet chip from trans and set my throttle body back to 4.47 wide open throttle.i am experiencing great runnability and i am going back to the track friday.
Old May 11, 2003 | 10:33 PM
Ajax's Avatar
Hey Lance, let me know about Friday. I'll run down there with you. I'm getting my stall, gears & shift kit put in next Sat.(if they make it in time), so I'd like to run it before & after.
Old May 12, 2003 | 06:13 PM
Formerly one92rs
yay i am planning on going. i want to see if this does any better.i am getting an x pipe on saturday so i am planning on going back to the track next week also.
